Magic Memory Stick & Pandora Battery
Mensagem por kebramar em 5/7/2008, 13:57
Sony PSP Downgrade / Unbrick Tutorial by kebramar
(How to)
Requirements:
. A battery with memory capability
. A memory stick with at least 128 mb and not bigger then 4 gb
. A PSP with the 1.5 Original Kernel (PSP Fat) or with the M33, OE or WC Custom Firmware (with the 1.50 Kernel addon installed)
(1st) Magic Memory Stick & (3rd) Pandora's Battery Easy Installer:
rapidshare.com Pandora_s_Battery_-_Easy_Installer.exe.html
(2nd) Despertar del Cementerio v. 5 (CFW 3.90 M33-3) Easy Installer:
rapidshare.com Despertar_del_Cementerio_v5_-_Easy_Installer.exe.html
Notes:
Note 1#: Win Vista users won't be able to use this method
Note 2#: Numbered by installation steps order
Note 3#: Your PSP must be running the 2.xx or 3.xx Kernel to run the Despertar del Cementerio application
Note 4#: When running the Pandora's Battery Creator application, if you get the error 20020148 it's because you need to change the Kernel version to 1.50 on the Recovery Menu
Note 5#: Before using the Pandora's pack, the battery's charge level must be at least 75%
Note 6#: If you don't get any result when using the Magic MS and the Pandora's Battery, run the Despertar del Cementerio application again
To use the Pandora's Battery as a normal one again:
. Turn on your PSP with the power cord plugged in but, without the pandora's battery
. When on XMB, place the the pandora's battery
. Start the Pandora's Battery Creator application from your XMB > GAME menu
. Press Square []
For the guys you want to make the Pandora's Battery using a PSP Slim (running a Custom Firmware), you ll need to run the Hellcat's homebrew from the PSP' XMB > GAME menu.
Notes:
Note 1#: Run it after running the Pandora's Battery - Easy Installer file.
Note 2#: If you use the PSP Slim battery (note that some PSP Slim batteries are patched so, you cannot use its memory capability) it ll work only on another PSP Slim. If you use a PSP Fat battery, it ll work on another PSP Fat or Slim.
Com os melhores cumprimentos, Filipe.
kebramar
Moderator
Moderator
Número de Mensagens : 56
Idade : 32
Data de inscrição : 11/01/2008
Re: Magic Memory Stick & Pandora Battery
Mensagem por kebramar em 5/7/2008, 14:01
For the ones who want a Custom Firmware full compatible with iRShell install the M33 3.80 version.
Despertar del Cementerio v. 4 (CFW 3.80 M33-5) Easy Installer:
rapidshare.com Despertar_del_Cementerio_v4_-_Easy_Installer.exe.html
kebramar
Moderator
Moderator
Idade : 32
